exhaust sound
Old 02-25-2011, 11:13 PM
pozesd99''s Avatar
Default exhaust sound
So a buddy of mine told me that a big cam will make my exhaust louder. Is this true
Old 02-25-2011, 11:21 PM
99Bluz28's Avatar
Yes it sure will!
If you going from a stock cam.
Old 02-25-2011, 11:24 PM
thegroup's Avatar
thats like asking "does a bear **** in the woods?"
basically yes
Old 02-26-2011, 12:09 AM
pozesd99''s Avatar
Well currently I have a 232/228..603/.598 110lsa cam. Car seems quiet with true dual x pipe over the axle with dynomax bullets. Been thinking about stepping up to a ms3 cam. So that would make a noticeable difference
Old 02-26-2011, 01:22 AM
cowboysfan's Avatar
more lope and a tad bit of increase in sound......
Old 02-26-2011, 02:53 AM
99Bluz28's Avatar
If you want it louder just dump the exhaust right before the axle tubes.
https://ls1tech.com/forums/14545804-post105.html
Old 02-26-2011, 06:10 AM
Captain Double Post
BOBS99SS's Avatar
Or just change to another type of bullet,could add cutouts ,etc,I run a big cam in my car and I like it but before I shoot some info out ,list your setup now,if its in your sig sorry my phone doesn't bring them up
Old 02-26-2011, 07:55 AM
trans_am7935's Avatar
i just ordered the longest Dynomax bullet they offer (like 23.5") in attempts to quiet my baby down after i install the heads and cam, hopefully it will work
Old 02-26-2011, 09:38 AM
Steve Gunn's Avatar
Get dual cutouts and all Hell will break loose! If your goal is to scare old ladys, set off car alarms and make babys cry, that'll do it!
Old 02-26-2011, 10:07 AM
X-ray's Avatar
Does Charlie Daniels play a mean fiddle?
Old 02-26-2011, 10:39 AM
99Bluz28's Avatar
Since you already have a nice size cam w/10* of overlap, going to a MS3 isn't going to change anything much. The MS3 has only 5.5* more overlap then you current cam.
IMO the answer is in the exhaust system, try replacing the Dynomax bullets with either straight pipe, or SLP resonators; that will make it louder!
Old 02-26-2011, 12:15 PM
pozesd99''s Avatar
How much louder will dumps make it
Old 02-26-2011, 12:29 PM
99Bluz28's Avatar
Quieter than a cutout at Idle, but about just as loud at full throttle.
Old 02-26-2011, 08:33 PM
pozesd99''s Avatar
Will it still be pretty dam loud with the dumps? How do I avoid the vibration when I get on it with dumps
Old 02-26-2011, 11:29 PM
The Mighty Texan's Avatar
Turning it so it doesnt bounce of the pavement or wheel directly will help, dumps will be pretty loud but not as much as a cutout. Like 99blue said the ms3 shouldnt be that much more different i dont know why you want to switch but i wouldnt if i was you
Old 02-27-2011, 08:26 AM
pozesd99''s Avatar
Well my whole set up is changing. My current cam is specd for 241 heads. Now I have ported 243 heads and need a bigger cam
Old 02-27-2011, 12:58 PM
99Bluz28's Avatar
Since you're considering a larger cam, what intake & TB do currently have, and I would still stick with a 110 or 111lsa for better low-end power.
Consider a custom grind w/CompCam LSL lobes:
#13019, 235 @.05", w/.621" lift, w/1.7 rockers
#13020, 239 @.05", w/.624" lift, w/1.7 rockers
#13021, 243 @.05", w/.624" lift, w/1.7 rockers
#13022, 247 @.05", w/.624" lift, w/1.7 rockers
IMO, If you really want to step up to a larger cam I think a 239/239(17* overlap w/111lsa) or a 239/243(19* overlap w/111lsa) with either a 110 or 111lsa would make you happy!
