A.I.R. tube question
the tubes that connect to the headers, is is bad to not have them tightened down all the way? Sorry if its a pretty retarded question im kind of a rookie with all this because its a PITA to put the bolts on that pacesetter gave me.
1 Post
If your referring to the egr/air tube that goes to the stock manifolds then yeah they need to be and also have good gaskets otherwise you will hear a loud knockish sound first couple minutes the car is running. I'm needing to order some right now actually
ahh gotcha, because pace setter sent gay bolts and i cant use the stock ones and they are ALL a pita to tighten and i heard the knock noise you guys mentioned, thanks for the heads up
