lsxr 102mm
lsxr 102mm
Hey guys. I heard lots of debate on this and dont wanna be yelled at. I plan on doing full bolt ons, a large cam like the raptr, 220 as casts, full ehaust. I was told to run the 92mm fast, but when i talked to vengeance, he said that nobody sells that anymore, becausd the 102 mm is better in every department. When i asked about low end, he said that they dyno tested it themselves, and the 102mm has minimal gains on the low end, but never any loss. and the mid-top end gains were good. im just wondering if this is true? becuase ive heard alot of people sayin that you lose a little low end on stock ci ls1 motors. Thanks
Read through this thread and it should answer your questions. If not, call and talk to Tony Mamo at AFR and he will school you on everything you need to know. This topic has been covered a million times over in here
https://ls1tech.com/forums/generatio...02-thread.html
