Hole repair for SLP intake
I have an SLP / LS6 intake that has a big hole in the back, and the spigot is loose. Since SLP stopped selling these I'd like to repair it and put it on my car. Has anybody ever tried repairing a manifold before. I wonder why SLP stopped selling these
I bought it on Ebay. It was delivered damaged. Seller didn't pad the back very well and the box looked like it was dropped on it's end. And no he didn't insure it as he said he would. I learned a valuable lesson about insured packages.
JB Weld. Try a search for repair ls6 intake and there should be a few threads.
Here is on of the better ones:
https://ls1tech.com/forums/generatio...xed-saved.html
I had almost the same damage on an LS6 intake and I used 4 coats of JB Weld to patch the hole.
Here is the damage prior to repair
Moderator
It's nylon 66. If it were me, I'd go get a black spatula from Wal-Mart
and a spade tip soldering iron and go to town on it (plastic welding,
shade tree style). Black plastic spatulas being the same material
minus the filler.
minus the filler.
I'd like to try the welding method but I'm told that spatulas have a Teflon coating on them and it won't adhere. I also can't find nylon 66 welding rods. I went as far as looking for someone that welds plastic, no luck around here
Having that fitting out made the repair much easier. It allowed me put a backing in place before the first coat of JB weld and filled back even with the inside edges.
BTW: When I was explaining this intake to an old school guy (he was dumbfounded when I mentioned a plastic intake) at work he mentioned that he had used cable ties and a soldering iron in the past to make plastic repairs. I just went with the JB Weld method as I had a large gap to fill as well as the cracks.
i woulda thought any decent sized body shop would have those plastic welding rods,doesnt anyone do the bumper reair/welding anymore?used to be a guy outside of town here that had sign saying plastic bumper welding,thats all he did...
Thanks for all the advise everybody
I couldn't find anybody around here that did plastic welcing so I stopped feeling sorry for myself, got off my butt and and repaired the manifold. I got a piece of the same material and welded a patch over the holes, using a soldering iron, and then applied JB weld. It's not West Coast Customs quality, but it'll do
