Valley Cover swap on LQ9
Old 03-15-2011, 09:55 AM
warbird27's Avatar
Default Valley Cover swap on LQ9
About to swap out valley covers on a LQ9 block and just wanted to double check that there is nothing different from switching the covers with a LS1 block so I don't run into any surprises. I'm assuming I still need to dremel a notch for the LS6 PCV pipe?
Old 03-15-2011, 10:01 AM
dodson55's Avatar
should be the same concept but i have never did it on a 6.0 so i not sure if you have to notch the block or not
Quick Reply: Valley Cover swap on LQ9
