LS1 intake to LS6 intake question
Old 03-15-2011, 10:35 PM
stanggreg90's Avatar
Default LS1 intake to LS6 intake question
Have a '99 Camaro SS...LS1 intake was swapped for LS6 intake and PCV on valve covers and throttle body were capped off. Is it supposed to be capped off? Car is a daily driver. Thanks.
Old 03-16-2011, 10:21 AM
Mumbles's Avatar
You should have been able to use the existing PCV System.
Unless, of course, the PCV System was removed and replaced by a breather on the Valve Cover, there is no reason it wouldn't work with the LS6 Intake.
Old 03-16-2011, 11:02 AM
It wasnt capped off before, i put a breather on it so it can breath after i say that. What is the best way to have it? Should i run a hose to the back of the valve covers into a T, and still have the breather?
Old 03-16-2011, 11:59 AM
99Bluz28's Avatar
IMO, run the fresh from the TB to the valve cover, cap the passenger side rear, run a hose from the driver side rear to a PCV valve then into a catch-can, finally back into the intake.
Sell the breather.
Old 03-16-2011, 12:28 PM
where is the pcv valve on a 99?
Old 03-16-2011, 02:20 PM
99Bluz28's Avatar
Toward the front of the passenger side valve cover(within 5" of intake port).
Directly below the white dot on the TB fresh air hose in the photo.
http://www.pc-surgeon.net/images/cforum/ops41.jpg
Old 03-16-2011, 03:12 PM
so it runs under the intake
