Aftermarket Belts
Old 03-17-2011, 04:00 PM
DC01SS's Avatar
Default Aftermarket Belts
I recently had to install both serpentine and ac belts on my 01SS and have had nothing but problems. All the belts do is squeak. I can apply belt dressing and it will stop for about 15 to 20 mins but then comes right back. What are the best aftermarket belts that I can buy or do I need to just put factory belts back on the car?
Old 03-17-2011, 04:09 PM
The Mighty Texan's Avatar
Gates belts are about the best you can buy. No problems with then here there some good ****
Old 03-17-2011, 04:10 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
I've always had success with the Poly-Cog belts by Dayco....but if there are other issues such as failing pulleys, mis-aligned pulleys, etc the best belt in the world won't stop the noise!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 03-17-2011, 04:21 PM
DC01SS's Avatar
The car just turned over 117,000 miles and hasn't had a tensioner pulley replaced or adjusted. What type of lifespan do you typically see out of those parts?
Old 03-17-2011, 04:23 PM
There is a good number of those tensioners failing daily! There was enough demand for a better tensioner that Katech made an aftermarket piece for it even, and now Comp and a few others offer similar!
__________________
Old 03-17-2011, 04:27 PM
DC01SS's Avatar
I'm no mechanic by any means and dont have a service manual but is there a spec and way to check the tensioner free play or anything similar to see if indeed it is out of tolerance?
Old 03-17-2011, 04:41 PM
RARON455's Avatar
It should be real tight, If you can push it easily, then its bad, or if it stays down its bad. I ended up using a goodyear gatorback belt to shut my squeeling up. worked for me.
Old 03-18-2011, 12:35 AM
IrocZTransAm's Avatar
Happy Dayco Poly Cog belt owner here. 6 years and going strong.
Old 03-18-2011, 05:38 AM
Tobias05's Avatar
Gatorbacks here, no complaints.
Old 03-18-2011, 06:11 AM
blackodium's Avatar
wow i have the same issue. only its the ac belt. i replaced the pulleys for the ac belt only and the belt is squeeling! im going to purchase a new belt today. if it continues what the hell do i do? as far as play on the tensioner very strong and does its job.
Old 03-18-2011, 08:04 AM
RARON455's Avatar
Try a gatorback belt,,it has serrated ribs to help eliminate squeeling. It fixed mine, I did everything before even sanded and polished on my pulleys still squeeled, Put the gatorback on and it went away right then
Old 03-18-2011, 09:48 AM
blackodium's Avatar
i also polished the pulleys. i will buy a belt thanks!
Old 03-18-2011, 05:07 PM
dtfastbear's Avatar
FWIW, i had a belt that I got at NAPA start squealing like crazy after only maybe 6-8 hours of track use. I thought it was the alternator at first. Then I was looking at the other pulleys and the water pump. I tried belt dressing and that made it much worse. I bought a new belt (again, from NAPA) and it is perfectly quiet now. I don't understand what could happen to the belt itself, but that was definitely the source of my squealing.
YMMV.
Dean
Old 03-19-2011, 10:52 AM
1A Dan's Avatar
I've always been a fan of Dayco belts, but Gates is top notch too; both have worked for me without issue
Old 03-19-2011, 11:01 AM
That's MISTER MODERATOR
Paul Bell's Avatar
I'm running Goodyear Gaterback Poly-V belts, 4060790 and 4040410
