Torqued new gm crank bolt wrong.
I made a mistake when installing my new gm TTY crank pulley bolt. I installed and torqued it to what ARP says for there bolt which is 240 ft lbs. I see now that I should have done 37 ft lbs and then 140 degrees for the new gm bolt.
The bolt is still very tight and seems fine after 4 dyno runs and about 50 miles of street driving should I just leave it or is it a must that I remove it and install a new bolt the right way.
Is there a torque number that coverts close to what the bolt would be after turning it 140 degrees?
I don't think I will either and I rather not mess with it if its not needed. I've read more then one thread about people getting very unlucky and breaking crank bolts off while removing them. But at the same time I don't want it flying off at 6500rpm either.
