How to tell between LM1 &2
I know I have an SLP setup of some sorts. But not sure which it is..any easy way to tell? The salesman said he thought the previous owner said it was an LM1 but I'm not sure. Any real easy ways to tell?
Thanks guys.
Thanks guys.
Easiest way of telling without tearing it apart (and yes i do know from experience, cause i've had both) is the actual tone. The lm1 has more of a straight pipe cackle to it through the rpm range and will pop and backfire like crazy if you let off the gas at higher rpm, where the lm2 is more bass heavy and alot more controlled as far as the extra "noise" from the packing and baffles. If your car sounds more straight piped and cackles alot, you got the lm1.
