afr 215s vs trick flow 215s
^ TFS has a smaller valve angle. 13.5*, IIRC. Stock is 15*... IIRC. This allows you to run a slightly more aggressive cam without having to worry as much about piston to valve clearance.
TFS also has some powerful mid to low lift flow numbers. THAT is where the money is. Both are, still, very good heads.
I bet they would all be within 5hp of each other...
PRC, TFS, AFR...
Cant wait till you and rob get your setups done...
