02 wiring polarity
Old 03-28-2011, 05:04 PM
drago1217's Avatar
Default 02 wiring polarity
i had to get my car back from someone and they let the o2 sensor extensions hang on the ground and rub apart. I have more than enough wire to splice them back together. they have 2 white 1 grey and 1 black. does the polarity on the 2 white matter or can i just connect them together any way. I'm getting horrible gas milage lol
Old 03-28-2011, 05:21 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Gray = Ground
Black = Sensor Output
White = Heater (12V and ground)
Doesn't matter which white goes where to which white, it's just shorting that current across an element to produce the heat for the sensor.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 03-28-2011, 06:39 PM
drago1217's Avatar
Thanks ill try splicing them first if I have a problem making a good connection ill order a new one from y'all but ill want to try this first
