intake and TB advise please.
Old 04-02-2011, 01:24 PM
Tzion_ben_Arthur's Avatar
Default intake and TB advise please.
I need some advice on my DD NA car. I was thinking about upgrading the intake and TB for some extra power, but I am not sure if it will be worth it. A little info on the car; it has a 383 with TSP 2.5 heads and a CC 228/234 custom grind cam. 11 to 1 comp, step LT headers and off road exhaust. It also has a 2800 vig converter and 3:55. The car runs decent mid 11’s on DR’s @118 MPH and gets about 23 MPG on highway. Right now it has an LS6 intake and stock, un ported TB. Will just a slightly larger TB provide a good increase or should I look at an intake and TB combo. Any suggestion that will not break the bank? Not looking to get crazy here… I have a turbo car for that.
P.S. EFILive, speed density tune.
Old 04-02-2011, 02:07 PM
garygnu's Avatar
I would look at a intake TB combo.you have a great engine combo that would benefit from better intake flow.I feel your ls6 intake holding you back.
Old 04-02-2011, 02:10 PM
Cool. Do you have a suggestion?
Old 04-02-2011, 03:22 PM
intenseblue's Avatar
Fast 90, 92, or 102
Old 04-02-2011, 06:03 PM
bayer-z28's Avatar
^ Yep. What injectors are you running now? I'd go with a Mamo ported FAST Fast intake. They're pretty much the best performers on the market for modified engines.
BBK SSI 85mm is good, but that'd be more suited for a bolt-on LS1, 346cui.
Old 04-02-2011, 07:35 PM
trusty 42's
Old 04-02-2011, 11:23 PM
99Bluz28's Avatar
You could send your LS6 intake to TPIS and have it converted to 90mm snout for $350, then buy a 90mm TB.
