Do LS3 injectors work with an LS6 intake?
They are not stock replacement but they can be made to fit.
You'll need ev6-ev1 harness
http://speed-eng.com/store/fast-fuel...ck-p-8953.html
and since ls3's are shorter some spacers
FAST 146025-KIT LS3/LS7 Fuel Injector Adapter Kit
LS1Tech Premium Sponsor
Other than the LS2 style injectors should be longer in length compared to the LS3 style injectors, but yes they do share the same "EV6" connector.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
yes! I bought some that i intend on using aswell
PM the fuel injection connection guy here on ls1tech he'll get you everything u need.
should be height adapters, ev1-ev6 harness, and new orings
they flow 42 lbs from the factory and are dirt cheap. Or u can send off ur stocker injectors and resize them for 30$ a piece to flow up to 55lbs or below
