Intake temperature melting point?
Old 04-10-2011, 09:46 PM
NTIMD8's Avatar
Default Intake temperature melting point?
Hey guys,
I wanted to paint my intake with a type of paint that requires curing at 500°F for 30 minutes. Does anyone know if the LS1/LS6 intake can take this high of a temperature for that long?
Thanks
Old 04-11-2011, 02:50 AM
ls1 1990 VN's Avatar
WHY! Do a search & check what others have used. There have been some quality paint jobs done.
Other wise, Good Luck.
Old 04-11-2011, 07:30 AM
NTIMD8's Avatar
Only because there is a particular colour I want (a certain Matt Red). If no one knows I can either just not cure it or try throwing my stock LS1 intake in the oven and see what happens. LOL
Old 04-11-2011, 04:06 PM
01ssreda4's Avatar
I wouldn't try it.
Old 04-11-2011, 04:09 PM
Kleeborp the Moderator™
MeentSS02's Avatar
At 500 degrees, I have a feeling it wouldn't last.
Old 04-11-2011, 06:11 PM
redbird555's Avatar
ya i dont think it would melt it but i do think that it may heat it up and get soft which could cause it to warp and not seal properly. if you really want a specific color take it a local place that sells ppg/dupont etc and have them match it to a base coat and clear coat paint then just have a shop spray it.
Old 04-11-2011, 06:46 PM
joecar's Avatar
Google search shows Nylon 6.6 has a melting point 255°C (490°F).
Common sense says to not do it, regardless of what Google found.
Old 04-11-2011, 08:25 PM
NTIMD8's Avatar
Thanks guys. I'll spray it and not cure it. It should still hold up fine.
Old 04-11-2011, 09:37 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Paint it and install it un-cured. Drive the car in traffic on a hot day. It'll cure.
Old 04-11-2011, 09:40 PM
LS1aiden's Avatar
Quick Reply: Intake temperature melting point?
