Throttle cable (?) Question / Problem..
Old 04-14-2011, 07:29 PM
Ghostintheshell's Avatar
Default Throttle cable (?) Question / Problem..
Ok guys. I have posted this question in the past with no answer - so I figured I'd get some pictures so people can see what I am talking about...
I have a 98 Trans Am that USED to have Traction control. The previous owner apparently disabled it. Regardless, I do not want it.
My throttle cable is broken. The small clip is missing - and during my tune, the tuner observed the throttle would remain slightly open after pushing the pedal down. We rigged the cable with some twist ties and managed to fix it - briefly.
So - here goes:
Here is the current set up:
SO - I bought a new OEM GM 98 LS1 throttle cable for a NON-Traction control LS1 - as my TC has been disabled.
(here)
My question is this:
WILL this NON-TC cable work?
Old 04-16-2011, 03:41 PM
And the mystery continues...
BRRRRRUMP!!
Old 04-20-2011, 08:14 PM
no one seems to have an answer for this one...
bump
Old 09-07-2011, 01:13 PM
bump!
Old 09-07-2011, 01:34 PM
Moderator
jimmyblue's Avatar
I don't have the part numbers handy but I've bypassed my
TCS "gizmo" using non-TCS cruise and pedal cables, bought
from the stealership.
These come without adjusters and you may have to bend
your gas pedal to get full draw. Other than that, life is good.
Old 09-07-2011, 08:42 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Although you haven't included the cable's part number in your post/question, it appears to be 12565559, which would be the correct cable for a non-TC LS1 F-body car.
Old 09-10-2011, 05:20 PM
It is for a non-tc car.
My car has TC (although disabled apparently, I have to get to the bottom of it).
For the life of me, I can't find a 98 throttle cable with TC.
So the question is using this non-TC cable on my TC equipped vehicle.
I'm not exactly sure what will have to be done - but apparently I can bypass the TC and use it.
Old 09-10-2011, 05:36 PM
Paul Bell's Avatar
For 98-99, GM part number 12552267 is the cable from the accelerator pedal to the TC. 12563242 is the cable from the TC to the throttle body.
Old 09-10-2011, 05:43 PM
I need the cable with the clip.
The clip is broken - and therefore the throttle is somewhat loose. My tune indicates it stays open a bit.
Old 09-10-2011, 06:45 PM
Paul Bell's Avatar
It's the second part number I posted above.
This may be a moot point as the part has been discontinued by GM. If you go to a dealer parts counter and ask them to do a search, you might get lucky and they'll find you one.
Old 09-12-2011, 09:13 PM
With the help of Paul bell I have located a replacement piece!
Awesome. Only took me 5 months!
Old 05-25-2022, 02:43 PM
Moderator
Black LS1 T/A's Avatar
And... after all that, he doesn't say where he located it...
Old 05-25-2022, 06:04 PM
Received 3,018 Likes on 2,349 Posts
After ELEVEN YEARS....I guess not!
The following users liked this post:
LilJayV10 (05-26-2022)
Quick Reply: Throttle cable (?) Question / Problem..
