car wants to die!!
Old 04-21-2011, 11:46 AM
Bad98SS's Avatar
Default car wants to die!!
I have a 98 ss with a iorn block 408 stroker in it. I brought my car home from storage last month and it ran great. I have had it in the garage to replace leant header gaskets.and a valve cover gasket. Since I have replaced those the car wants.to die when I come to a stop and push the clutch in, where it would normal go back down to idle its will die.if I.don't gibe it a little gas, after I give it some gas it will go back to.idle and be fine. Icant figure out why it would all of the sudden jus start doing.this after fixing a few gaskets. Any ideas? Thanks
Old 04-22-2011, 05:33 AM
ozzman98's Avatar
strong possibilty it could be your mass air flow. i had a simular problem an it ended up being my mass air. my idle would float from like 300 rpm's to 1100 rpm's wen i would slow down. then just die wen i came to a stop or a lil before.
