Intake?
Old 04-25-2011, 07:39 PM
96juicedgt's Avatar
Default Intake?
I have a 2000 z28 m6 with long tubes, ls6 intake, and soon a g5x3 cam. I was thinking about purchasing a fast intake 92mm combo as well. I was wondering if this would work well with this setup or if I should stay with the ls6 intake? Thanks in advance Jared.
Old 04-25-2011, 07:45 PM
ULTIMATEORANGESS's Avatar
yes, youll get a nice power gain.
Old 04-25-2011, 08:04 PM
96juicedgt's Avatar
Also wondering what size injectors should I run, as I am planning on running a wet kit on it to. Thanks for response.
Old 04-25-2011, 10:12 PM
TXZ28LS1's Avatar
The fast will definitely make gains over a LS6 intake. The thing is the fast intakes are very pricey. So some will say keep your LS6 intake as guys have ran fast with a LS6 intake, and some will say if you have the money go with the fast. Depends on how much you really want to spend.
I have an LS6 but might look into a fast 90/90 (which they no longer make) if i could find one used.
Old 04-25-2011, 10:24 PM
180ls1's Avatar
it will but it depends on what you consider worth it. Would you be happy spending in excess of 1,000 and gaining 10-15rwhp? I would get heads first.
