ldler pulley screams
Old 04-29-2011, 05:38 PM
forcerecon's Avatar
Angry ldler pulley screams
sorry if this has already been said.but ineed some advice.98 z/28 accessary idler pulley started screaming after sitting for a month this winter.i know it's the pulley because using a stethescope, noise was coming right from idler pulley and no where else.i replaced the pulley and the same squealing is coming right from the new one.it goes away for 30 seconds if i spray a shot of wd-40 behind the pulley.any ideas appreciated.
Old 04-29-2011, 06:01 PM
speedsk899's Avatar
I have the same problem...thought it was the idler so replaced.....still there...turns out the stock crank pulley can cause this. I have used some belt dressing on it and it works for a while. I don't really drive the car so its not a biggy for me.....
Old 04-30-2011, 08:59 AM
sabersaw30's Avatar
https://ls1tech.com/forums/general-m...ease-pics.htmlHope this helps helped out on mine.
Old 04-30-2011, 01:02 PM
The Mighty Texan's Avatar
^ That. Make sure if you go for re-greasing you clean everything really well and get all the old grease out and such, if not chances are it will return.
Old 04-30-2011, 01:10 PM
speedsk899's Avatar
Whats the point in re-greasing the bearings? Its a brand new pulley and bearings
Old 04-30-2011, 03:33 PM
mikey67's Avatar
New pulleys aren't always greased very well from the manufacturer.
Old 04-30-2011, 03:42 PM
speedsk899's Avatar
Then I would take it back and get a new one.......
