Removing Power steering pulley... anything special?
I need to replace my power steering pulley (chipped... so I keep throwing belts... not fun when it's dark out and cars are flying past at 70mph)
Do I need any special type of puller to do this? (I have 3 pullers now... 1 for removing my stock crank pulley, 1 for removing my ASP pulley (generic puller), and a puller for removing S/C pulleys) ... will any of them work?
do I need to take the P/S pump off in order to swap pulleys or can it be down in the car?
Thanks
Thanks
Originally Posted by 2001CamaroGuy
You don't need to remove the pump to replace the pulley. There is a "power steering pulley" puller which is different than the crank pulley pullers. You will also need a bolt to put the new pulley on (threads into the pump shaft and pulls the pulley on).
oh ok... i'm assuming this is just something I can get from my local hardware store? Any idea on the size and thread pattern ?
Thanks!
Mike
(oh and 2xLS1 thanks for the link, i'll stop by autozone and rent it )
No; you must use a Pitman type puller for this job. It has a special pair of flat round jaws.... they sell them cheap at www.JCW.com.
It is easier to remove the pump using the pulley puller first but you can also remove the three bolts securing the pump to the car with the pulley still installed on the pump. (A real bitch with a stubby wrench, however) If you decide to do this, becasue you do not have a Pitman puller, take the whole unit to Autozone and have them remove the old pulley and install the new one.... their charge should be around ten bucks...
You should flush out the system which ever way you go....
The Autozone tool I posted a link to has everything you need to both remove and reinstall the pulley. There is NO CHARGE to rent tools at Autozone. You pay for the tool and when you are through, you return the tool for a FULL refund. Sorry Robert. Sometimes you are just flat out wrong.
Originally Posted by Steve1969LS1
You can buy a new billet pulley for $50 and never worry about chipping it again.. just a thought.
Originally Posted by wrencher
Why dont you ask local Mikey???????
