Is there an easy way to drain the block of coolant?
drain the radiator then close everything up. remove the coolant bypass, then use a shop vac and the mentioned coolant plug, close it then from the bottom rad. hose.
Removing the block plugs like mentioned above are a pain to get to, but will help. The lower radiator hose is lower than the water pump ports on the block, so it shouldn't be to messy by just removing the lower hose first and letting it drain. I used a shop vac to suck water out of the block when swapping heads, but you need to have the water pump off first.
There's another drain plug on the passenger side too:
I have a lift, so getting under it isn't a problem. I've done this before, but just remember it being a big mess. Oh well. I could always just unhook the lower heater core line from the water pump and try draining that while using a shop vac to catch as much as possible.
Thanks guys. After 10 years and countless mods and work done myself, I still learn something new each time I tear into the motor.
I'm just trying to avoid the mess on the floor when you break loose the bolts on the water pump. It's not a big deal, but if there's a better way, I'm willing to try it. I just hate cleaning up messes that I can avoid.
Pulling the ECT sender will drain quite a bit out of the block, and it's super easy to get too. Mine broke when I pulled the manifolds off to put my headers on, that's how I know it will drain a lot out, haha.
Isn't the top radiator hose higher than the block? It's not going to drain out the block that way.
Ha yeah it's right in the way when doing headers/plugs/etc. mine was just old and brittle, I didn't even hit it (that I know of), just found it with the two pins sticking out and the rest still plugged into the harness. Luckily NAPA stocks them for under 10 bucks!
Save the manuals!
Hoooooooly crap. What a disaster.
How did you end up draining your block? Shop vac and a tube? Or did you skip it and just do the radiator?
My coolant is so old that it has hair - so I'm doing a full flush and want everything out. It looks like the only way to get to the large plug on the driver's side is to take the damn alternator out. I don't really want to do that, especially since it's going to make a mess and I'll need to do it twice to run the engine for the flush and then drain it all a second time before new coolant goes in.
I've drained my radiator, but it looks like it only holds half the coolant in the system. The block is still holding on to a ton.
