Ditched the junk pacesetter y-pipe for this!!!
Old 05-19-2011, 06:35 PM
silverz28camaro's Avatar
Default Ditched the junk pacesetter y-pipe for this!!!
Old 05-19-2011, 06:36 PM
After seeing Chrs1313 pick up 30 ft.lbs in the mid range I decided its time to swap out this cheap setup for something that flows alot smoother....
Old 05-19-2011, 06:37 PM
The old y-merge necked down from 3in to 2 5/8 at the merge... the new setup is 3in into a 3.5 inch.
Old 05-19-2011, 06:40 PM
With the old setup I blew compressed air down the right bank tube and air blew out both the outlet and the left bank side... after welding up the new y merge I did the same test....When I blew compressed air down the right bank tube it created a vacuum on the opposite bank, should help scavange alot better
Old 05-19-2011, 06:41 PM
Old 05-19-2011, 06:42 PM
Total weight savings wasn't as much as I was hoping , but it was some.
Old catback was 35lbs, new setup is 18lbs, so 17lbs, not to bad as long as I gain 10-15 hp at the dyno...
Old 05-19-2011, 07:00 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Interesting... did you make that custom or did you buy part of it already made?
Old 05-19-2011, 08:25 PM
I bought it all in sections from this place...the muffler is a flowmaster race outlaw, and I'm also adding a magna flow on the end of it, more pics to come
http://www.mandrel-bends.com/catalog...04ss-1170.html
Old 05-19-2011, 10:27 PM
dug
dug's Avatar
looks good. what does the fm outlaw muffler look like inside?
do you have a link to chrs1313 dyno?
Old 05-19-2011, 10:51 PM
https://ls1tech.com/forums/dynamomet...p-426rwtq.html
Old 05-19-2011, 10:53 PM
The flowmaster outlaw muffler is a straight through design with ring welded into the inner parts to lower sounds by only 2-3 db. Very loud, thats why I will be adding the magna flow. I mainly wanted the flowmaster to rid the system from rasp.
Old 05-19-2011, 11:57 PM
Old 05-20-2011, 12:12 AM
MasterTomos's Avatar
Do you have a link to where Chris1313 experimented with this? Did he gain 30 ft lbs from just switching the y-pipe collector or the entire style of exhaust system?
Old 05-20-2011, 02:32 AM
01ssreda4's Avatar
Nice shoes.....Asics?
Old 05-20-2011, 06:37 AM
UNDER PRESSURE MOD
According to the link, he went from QTP 1 3/4 headers with a shitty ypipe to ARH 1 7/8 headers with a high quality ypipe. So I'm guessing that he gained from both of those changes.
Old 05-20-2011, 04:45 PM
WSsick's Avatar
Looks good Brad, now you just need to get a sound clip.
Old 05-20-2011, 04:56 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
That new Y pipe is much nicer. I don't know why companies don't make them like that to start with.
Old 05-20-2011, 07:15 PM
I'd have to say it because of cost, and maily that people want a slip fit without welding, if you wanted to go bigger then 2 5/8...factory slip size to the catback, you would need to cut the old section off and re-weld, but it would be well worth it
Old 05-20-2011, 07:29 PM
Carter01's Avatar
Nice work!
Quick Reply: Ditched the junk pacesetter y-pipe for this!!!
