KG3 Alternator/Underdrive Pulley Belt?
I just got done installing the kg3 alternator and the big 3 upgrade. I was then going to put the belt back on and it was way too tight. I was barely able to slide the belt over the tensioner pulley. I have a powerbond underdrive pulley and was using a 760K6 belt before the kg3 install. Which belt am I suppose to use with a underdrive pulley and kg3 alternator? The alternator came off a 04 silverado 6.0L.
I compared pulleys and they were the same. I looked at many threads and everyone said the kg3 alternator and factory alternators use the same belt. Do I have the wrong alternator or is this normal? Anyone else with a kg3 alternator and underdrive pulley? Which belt did you use?
