Any have Just FAST90/90 and LT Headers..come inside
Just curious..
Currently those are the mods i have plus 85mm maf, and 98mm lid.
I'm having idle issue with the throttle sticking at around 1200rpms in between shifts and it likes to hold that if im driving unless i blip the throttle.
Anyone else have the same issue? That and its running rich for sure.
I'm just wondering if all the added air coming in is throwing off the computer.
thanks...
-Chris
thanks...
-Chris
Fast 90mm TB are crap.
Put some grease in it and open and close the blade, should be able to see where it's dragging. Grind with a dremel there.
It might not drag in your hand, mine would only do it once bolted to the intake. Also spray some lithium grease into the throttle cable sleeve and the throttle pedal pivot point where it bolts to the firewall inside the cabin.
Also you will need a tune bad between the headers, intake, and tb. Contact Frost on here for an awesome mail order setup. For a small fee you will have a car that drives better and picks up more power. Likely 10-20hp with those mods.
I took it apart last weekend. it was catching.. i dremeled it. Took it apart and lithium greased it. I even polished it up. I still have the same issue. I checked all vacuum line and even undid the intake and re-torqued it down. Still doing it.
Not sure what to do now... besides wait for my tune..
