Installing 2step - Need wiring help
Trying to tap a wire into the clutch pedal position switch (12v when clutch in) but i can't find a wiring diagram of a 2000 Camaro to find out which wire to tap into. I found one for a 2002 trans am but im not seeing the same color 4 wires that is on that diagram.
Does anyone know where i can find a wiring diagram or which wire it is?
I found this http://www.tafmotorsports.com/images...g.diagrams.pdf but i can't seem to find the wires im looking for.
I think its on page 36/56 , the clutch pedal position switch at the bottom ( the pink wire ) , only problem is i can't find that wire for the life of me under the steering wheel. P.O. had a aftermarket alarm installed and now theres so many wires i don't know whats what.
Does anybody know where this switch/box/wire is?
Got it working. Should of just searched LS1tech in the first place.
https://ls1tech.com/forums/generatio...need-help.html
It was the grey wire he talks about.
