Will I need a retune? LS6 intake.
Old 06-11-2011, 12:14 AM
VandykeT/A's Avatar
Default Will I need a retune? LS6 intake.
Once I put the FAST 102 on my Trans Am i'll have my stock LS6 intake laying around so I figured i could put it on my camaro. The camaro is only bolt ons. I know the injectors are different from 00-02 so Ill stick with the camaros 26s. If all i change is the intake will I need a retune? My EGR is all ready deleted.
Old 06-11-2011, 12:22 AM
baalic's Avatar
Need... Probably not.. Should you? Probably yes.
Old 06-11-2011, 01:12 AM
Starz T/A 17's Avatar
You don't have to, but there will be power left on the table if you don't. But thats with any modification.
Old 06-11-2011, 01:21 AM
lemons12's Avatar
You already have a tune for the other mods?
If no I would get a tune.. if yes I wouldn't worry about it.
Mail order will be fine.
Old 06-11-2011, 08:34 AM
VandykeT/A's Avatar
I'm gonna be putting a torquer 2 in it eventually so I'd just have to have it tuned twice if i tune it for the intake. I didn't know if i'd have to do both at once. Thanks
Old 06-11-2011, 08:45 AM
bayer-z28's Avatar
I ran mine for a year without a tune. It's a good idea though.
Old 06-11-2011, 09:38 AM
LSX Mechanic
Damian's Avatar
Aside from the EGR delete, a slight touch-up on the AFR is needed but other than that its basically a direct swap.
Old 06-11-2011, 10:37 AM
ULTIMATEORANGESS's Avatar
Smile
since youre planning on adding more mods wait till everything is done then get tuned.
Old 06-11-2011, 01:26 PM
lemons12's Avatar
Do you have a tune for everything else?
If you plan on a cam in the near future hold off.
Old 06-11-2011, 01:33 PM
senicalj4579's Avatar
If geting more mods in future then wait for the tune. I did just about all boltons on my old 98z without a tune. Ended up just using a vinci handheld for a tune after.
Old 07-11-2011, 12:18 AM
2000PewterT/A's Avatar
Yup, there is no reason to get it tuned more than it needs to be. I would wait until you have everything finished.
