Help choosing underdrive pulley
Old 06-18-2011, 08:17 AM
dphc18's Avatar
Default Help choosing underdrive pulley
Just wondering what everyone's experiences are with these options, first I have been told the 25% will make lights and stereo dim? Then whats better, a solid pulley like ASP sells or a fluid dampner like speed inc sells?
Old 06-18-2011, 08:28 AM
ULTIMATEORANGESS's Avatar
Smile
i have an ASP. no problems for over 10 yrs.
Old 06-18-2011, 09:09 AM
Mike Morris's Avatar
Have the slp/powerbond-no problems
Old 06-18-2011, 09:42 AM
LSX Mechanic
Damian's Avatar
ASP.
Power bonds are heavier than the stock pulley. I don't really see the point in attempt to reduce accessory drag, while adding rotating mass at the same time.
ASP pulleys are lighter, and you can start the threads on a stock bolt to begin seating it. Power bonds are heavy and require a crank pulley install tool to get them started.
Old 06-18-2011, 09:45 AM
RibeiroBJJ's Avatar
Originally Posted by Damian
ASP.
x2 on the ASP..same goes for the trucks...usuaslly ud pulleys come with a od alt pulley....I have a Trickflow and its ok...ASP is better
Old 06-18-2011, 10:02 AM
Zmg00camaross's Avatar
I was going to go with the ASP is it worth getting there altnator pulley also?
Old 06-18-2011, 12:35 PM
ASP.
i did not know power bonds are heavier than stock.
im glad i went with an ASP.
Old 06-18-2011, 01:33 PM
2nd Gen Fl 'bird's Avatar
The "fluid" type dampener will control harmonics better. Yes, heavier but, the weight is concentrated to the center of pulley. The reduction in the diameter is where the power is picked up(moment of inertia). An engine dyno most likely couldn't see any power difference. We're talking 4-5 lbs difference between the two types. If you find a good deal on any, just grab it. Just sayin'
Old 06-18-2011, 04:10 PM
01ssreda4's Avatar
Bunch of freakin Powerbond/SLP haters in here. Weren't your precious ASPs coming apart at the hub on some occasions?
Old 06-18-2011, 04:14 PM
jc98ss's Avatar
i think my March 25% might be a good bit heavier than stock.....which is the lightest UD pulley out there?
Old 06-18-2011, 05:32 PM
dphc18's Avatar
Good info as of now I'm leaning towards the fluid type,
Anyone else have any info?
Old 06-18-2011, 08:02 PM
LSX Mechanic
Damian's Avatar
The older ASP's were coming apart, but they were also not SFI approved.
Their new design is SFI approved, comes with certificate, and doesn't come apart (I've installed probably 50+ since redesign).
The powerbond is a nice piece and has timing marks which is cool too if you actually use them. However I don't see the point in trying to reduce drag, when you increase weight on the crank at the same time. They cancel each other out.
Old 06-18-2011, 08:25 PM
Smile
my ASP is ancient and never gave me a problem.
Old 06-18-2011, 09:37 PM
01ssreda4's Avatar
I got ya Josh, but lets look at things realistically. What you are arguing is spinning drag. So lets talk about that. All 3 that we are discussing that I know of are 2 piece designs. Meaning: 1 piece hub (what goes on the crank), 1 outer piece (where the belt rides) and the 2 pieces are connected by a ring of bonded elastomer (rubber basically). The problem at least originally with the ASP units was that (for weight reduction reasons) the inner hub piece was aluminum. This apparently caused some separation issues as the units aged. The stock unit is some kind of cast iron or steel and the powerbond unit is all steel. The Powerbond unit has raised steel beveled edges to help keep the belt from throwing. I think possibly the stocker is around 12-14 pounds, Powerbond is near the same, and ASP is about 10 pounds or so (all estimates). So, ASP managed to eliminate weight in the most unfavorable place, the closest spinning area to the crank snout. This would not be as beneficial as making the outer ring in aluminum. But, there has to be a reason why they didn't make the entire unit in aluminum...not stable enough, not strong enough, manufacturing costs etc. As an example of the spinning weight savings of a hub made of aluminum try swinging a 5 pound weight on a 3 foot string, then try it on a 1 foot string. On the shorter string you are actually moving the weight less distance therefor requiring less energy. The actual point of an underdrive pulley is to spin the accs slower and thats where the power/throttle response is gained. Adding 2 spinning pounds 1 inch from the cranks centerline is irrelevant in this case
Old 06-18-2011, 11:56 PM
Tried an ASP out and threw belts
My current HEAVY SLP in 2 years has given me ZERO problems and never threw a belt
Old 06-19-2011, 03:26 AM
The Scammer Hammer
dr_whigham's Avatar
Well, that just solidified my decision.
01ssreda4, you no longer reserve the right to call MY alliterations silly (see my LS6 TB transition plate thread)
Seriously though, that's a great explanation anyone should be able to understand. I too have read and heard of the ASP's problem at throwing belts. I take it that's an N/A problem too, or just the FI guys?
Old 06-19-2011, 04:11 AM
01ssreda4's Avatar
And....let me simply and appropriately answer this thread with:
Been running a Powerbond for years without issue.
Old 06-19-2011, 12:05 PM
LSX Mechanic
Damian's Avatar
Must be installer error. I've never had one problem out of an ASP pulley and I've probably installed 10-20 a year since 1999.
Agree to disagree.
Old 06-19-2011, 11:01 PM
csilvers1984's Avatar
the asp alt pulley.........whats the purpose of this?
Old 06-20-2011, 07:31 AM
Tobias05's Avatar
different pulley size than stock to speed the alternator back up after installing the underdrive crank pulley. helps offset minor voltage issues.
Quick Reply: Help choosing underdrive pulley
