BBK 80mm TB, Built motor and TPS
Old 06-18-2011, 04:21 PM
zapp109's Avatar
Default BBK 80mm TB, Built motor and TPS
Quick question I have a BBK 80mm throttle body on my LS6 foxbody, it has a bit higher compression and doesnt like to idle with the TPS set at .57volts. My question is if i turn up the idle screw so the car idles well its at about .70v range. Do i need it to still be at .57v at idle with the screw set where i need it? at idle it is at 0% open just higher volts with the screw open where i need it to be. Also i bought the car with the bbk on it. Any thoughts on this throttle body is much appreciated.
