which 1 should i do first and which will show biggest gains?
i have a choice to add either 373 gears into my car or a set off pacesetter longtubes and off road y pipe currently running 273 gears car runs a 13.81 @ 104 with a 2.15 60 ft.which should i do first?
Well, swapping the rear end gears will put you at a higher risk of breaking that stock 10 bolt. The headers will help some. If you use the car as a daily driver and can't afford breaking it, maybe you should just leave it alone. Trust me, the more mods you do and track time you put on your car, the more likely it will break. Either the transmission or rear. Those are not cheap to fix either. What part of Maryland are you from?
im in temple hills md and as for the breaking i want to just get my car into the 12s with out a high risk of breaking i know its possible i have decent mph thru the 1/4 just need a better 60 ft
I had the stock 10 bolt with 3.42's and went 12.12. It is possible. I would have to agree with the other guy on a stall and tranny cooler. The 3.23's or 3.73's will work either way, both are better then the 2.73's you have now. It might be good for you to read this: https://ls1tech.com/forums/new-ls1-o...anna-fast.html
interesting information i really want a stall but for reliablity purpsoes think ima hold off for now even with a trans cooler stalls make transmission go out a whole lot faster.as for the gears i will probly instal the 323 since i already got them. and i will do the headers first since that wont put me at high risk of breaking also adding a cutout for when i need a beeter flow
i went 11.99 with a 3800 stall on a stock tranny with cooler. i have LTs, intake, few suspension goodies.
the 3800 stall is very driveable. more than i thought it would be
i have a buddy trying to sell me a tci streetfighter stall i believe its a 3200 to 3500 convertor for 200 bucks but here the whether is constantly over 90 degrees and with me driving every day even with a cooler ima afraid i will have some slippage
They are a low quality piece and even if given to you at a killer deal, it would not be worth it.
About the 4l60e.
A lot of people will tell you its a pos, and that it will fail you in no time.
I myself have run over 28 bottles of nitrous through that trans, consistant 11.66-11.70's with 1.65 60' times for 2 years w/o any issue whatsoever, stock 10 bolt with 3.42 gears.
Now I did, [ just 6 weekes ago ] install a FLT lvl4 w/a yank ss3600 stall, to support my bigger nitrous shot [150].
But that trans was running as good as ever the day I pulled her out.
Regular maint. and a good cooler are very important for trans life.
And I am not an exception.
Do a search, and look how many guys are on their stock trans and running
11's, not to mention a few in the 10's.
The big question is how much money do you have to spend?
That will help us tell you what you should lean towards.
His car has 134,xxx miles. It WILL need a rebuild soon especially with mods and track time.
to dannyz post. 28 bottles of 75 shot nos is not much. lol. jk you and those guys mentioned are lucky and probably dont have much milage, and use as a true daily driver. or just bsing about being stock trans.
