Is it worth it ?
Is it worth it ?
I have a 2 1/2 inch ypipe right now and stock piping with just a hooker muffler. Is it worth changing everything out to a 3 inch, ypipe and catback exhaust. I was thinking of doing that and putting on a underdrive pulley to pick up a few more ponies but not sure if its worth it doing that. What do you guys think.
on headers or stock manifolds? input more details. from your mods in sig. it says bbk LTs, i know for a fact they are 2.5". going to all 3" requires cuting your collectors(i think) or its still going to be a restriction. you can also consider a 3 inch merge?...but over all with headers and 3" all the way id say yes its worth it, other than that id spend the money somewhere else.
If you're sticking to a Y-pipe there is no reason to go to a dual 3" Y into a single 3", I would put a 2.5-3" merge on it and a full catback. Two 2.5" pipes flow slightly better than one 3.5" does, so if you are going to stick a 3" catback behind them there is no reason to go with 2 3" into 1 3".
I thought most 3inch ypipe's will fit most LT's. I know the ypipe that came with the BBK LT's are 2.5's but the connection wether its 2.5 or 3inch should fit right up to the headers i think but im not sure maybe someone can chime in that knows it for sure. On the other comment above i have an 01 Camaro doesnt that have the LS6 meaning 01-02's.
Yup you have the LS6 intake already, and it wouldn't make sense to go with a 3" y-pipe into a 3" catback, you will gain nothing over the 2.5". The only way a 3" Y will help is if you go to a 4" catback. I'd just get a 2.5"-3" flowmaster merge with a 3" catback and call it good.
That's what sucks about these cars, I wish they would have came with duals from the factory. $1600 for the Kooks duals is too much, and dumped duals is way too loud in the car.
Are you sure? Where did you come up with that? A pair of 2.5" pipes have an area of 9.82" vs 9.62" for a 3.5", I would think that they would flow better then? Unless I'm missing something about how exhaust flows, but I would think more area=better flow on something like exhaust.
https://ls1tech.com/forums/generatio...e-worried.html
i make 450rwhp and only have a 3in ory and matching magnaflow catback. i wish i had the cash to upgrade to 1 7/8 and duals or big custom y and cb. the ops money could be better spent on a cam.
