1998 PCV Replacement
OK so this is my 1st try on posting pictures and how to so give me a Break
Parts needed: Pic #1
1 PCV Valve part# PCV1199
3 feet of 3/8" Fuel Line
Dorman 3/8" fuel line brass Tee part# 788-031
HELP! PCV end assem. part# 46017
help! 90 DEGREE SOFT BOOT PART# 47029
2000-2002 Driver Side
PEX SharkBite 1/2" X 1/2" Elbow from Home Depot.
Pic #2 the Old ****.
Pic #3 The Culprits.
Pic #4 My completed Project.
Pic #5 Rubber Boot for Driver Side Valve Cover
Pic #6 Brass Fitting for 2000-2002 Driver Side Valve Cover
You will need to re-use a couple of small pieces of the OLD Hard Plastic tubing as Connectors.
I used one short piece maybe 2" long to connect the rubber boot on the Driver side rear of the valve cover this is the boot I don't have a part# for because I replaced this earlier this year.
I used another small piece to connect the PCV Valve to the fuel line.
The Fuel line going across the back is 18" long
The fuel line going from the back to the PCV Valve is 17" long
The Fuel line going from the T to the passenger valve cover back is 7" long
The Fuel line going from the Passenger valve Cover front is 10" long.
Like I said this is Just what I did maybe you have a Better Idea. Hope this can help someone.
OK now picture #5 is the boot that goes on the rear of the Driver side valve cover.
picture #6 is the Brass Fitting for the Driver Side Valve Cover 2000-2002
Stop busting the guys *****. You obviously don't get the point of this thread. The rubber fitting sections on the PCV system are very prone to failure over the years. A new setup is probably getting very difficult to find, and runs close to 100 bucks at a dealership. Some people need/want to keep things original. Not everyone wants to pull the intake to install an LS6 valley cover. In my opinion this thread should have been made a long time ago. And if you don't agree with what the OP is doing, then your solution is the red X at the top right hand side of your screen
Just kidding. I did something similar last year except I used a dual catch can setup from Saikou Michi. Works pretty well.
Yeah I was going to say...
So since I found this while the intake was off, can I reinstall the intake and still be able to access what I need to replace this hose afterward? I removed AIR at the same time. And how much does it hurt to drive maybe 40 miles or so without the system hooked up? (assuming I block off the holes in the intake and TB where the hoses go)
So that 1/2" x 1/2" brass fitting threads into the back driver's side valve cover?
Edit: Are you telling me the 00-02 used a threaded fitting and 98-99 used a rubber boot that plugs in?
I redid my pcv lines recently and another good option which is what i use is to take the orifice style pcv that comes in the 4.8 and 5.3 engines and drill it out with a 3/8" drill bit to ensure enough flow to put on the back of the driver side valve cover.
Bumping this thread. I failed smog because my PCV hose was ripped in half and used this to repair it. I found the parts to be correct in the writeup, with 2 differences. The brass T fitting part number was wrong. But there is only one 3/8" fitting in the help section. Also use the truck PCV valve, for me it was #1099 at autozone. For me the cost was around 30 bucks and I had to use 2 small hardline pieces from my old tubing
