what coils do i need?
Old 09-02-2011, 09:40 PM
little_chewy_69's Avatar
Default what coils do i need?
i have the stocks coils at the moment. I heard that the MSD ones are impractical. What coils do i want?
Old 09-02-2011, 10:04 PM
That's MISTER MODERATOR
Paul Bell's Avatar
What year is your ride?
YEP, many have had problems with MSD coils. Going to LS2 coils is a little step up. Going to the LS2 truck coils with exposed heat sinks is the big step up. F/I guys use them.
Whichever coils you move to, you'll need the LS2 style matching brackets and the coil harnesses.
The truck coils work best with a tune for them.
Old 09-02-2011, 10:53 PM
parks450's Avatar
Agree on the truck coils with heat sinks. Highest output of most gm factory coils.
Old 09-03-2011, 10:05 AM
2nd Gen Fl 'bird's Avatar
MSD makes some good stuff but, this area they should have not gotten into. A 10 year old article said it was going to be very hard to improve on the factory coil. Use them.
Old 09-03-2011, 12:16 PM
LS1-450's Avatar
What they said...
LS2 & LS2 truck coils w/ heat sinks are proven winners. There is a thread in here where a member used a Megasquirt to control spark through a spark plug & even increased the plug gap through a high RPM range. The LS2 & LS2 truck coils delivered a powerful spark regardless of gap/RPM. The Truck coils delivered a stronger spark than the LS2. However, the LS2 coils performed very well. There is really no question about it, LS2 & LS2 truck coils, FTW. Should add that a tune is not required. It is possible, through tuning, to change the dwell time to an LS2 table, but, is not required. If you have tuning software, go ahead & do it. Not an issue if you don't.
Don't waist your time/money on MSD coils that are both expensive & known to have had issues.
Old 09-03-2011, 12:35 PM
cookba's Avatar
difference between the LS2/truck coils and LS9 coils?
Old 09-03-2011, 10:24 PM
LS1-450's Avatar
I haven't seen any testing where the two are compared. Perhaps if the LS9 coils have heat sinks, they could be equal to LS2 truck coils. Would a$$ume that GM followed through into the Gen IV coils what was learned from the LS2 truck coils.
Check U-tube. Technical guys tend to download video test results there.
Old 10-08-2011, 04:36 AM
shaulinmathvader's Avatar
POk so lets say we want the ls2 truck coils with heat sinks. How do we buy them. Can we get them at the autoparts. If not what vehicle do they come in and how do we get the harnesses
Old 10-08-2011, 07:06 AM
Paul Bell's Avatar
What is your vehicle??
Yes, you can buy the coils at parts stores like Pep Boys and Auto Zone but they will not have the needed wiring harnesses (assuming you have an LS1) and the mounting brackets.
Everything you need to know is here:
https://ls1tech.com/forums/12985321-post1.html
Old 10-15-2011, 11:49 AM
EVIL_Z06@yahoo.com's Avatar
MSD stands for mutiple spark dissaster. Stay with GM.
Old 12-29-2011, 12:48 AM
novaflash2002's Avatar
this is old but what the hell msd= might suddenly die.
