360rwhp possible?
360rwhp possible?
98 z28 a4. Mods are gonna be SLP lid, ported stock tb, 160 thermo, ls6 intake, Texas speed 17/8 lts and true duals, 3.73 gear and dyno tune. Just tryin to guess where I'm gonna be at power wise
especially if its a dynojet (i dont think it applies as much in mustang dynos) i believe the 3.73s actually hurts the power from what ive heard due to the lower amount of load the motor sees
Numbers with an auto are pretty lame. I'd be more worried about track times.
I made 349rwhp SAE with the mods in my sig, converter unlocked. Different day (cooler, car wasn't heat soaked), without the UDP it made 370rwhp SAE converter unlocked. Car traps 90mph in the 1/8th with an approximate raceweight of 3700+ in DA of ~1900ft+ though (this calculates to 375-395rwhp depending on which calculator you use).
Intake, slp under drive pulley, fast intake, headers, ory, mild cam should really get you there. Should check into the water pump with the items u have listed that should get u close enough.
