cam degree quesiton (quick)
Old 09-21-2011, 02:27 PM
3rdCoastPowerSports's Avatar
Default cam degree quesiton (quick)
i read the other threads and have done my research but... when degree a cam with the heads off do i have to use a solid lifter? and if so what solid lifter do i need to buy?
Old 09-21-2011, 08:29 PM
S10xGN's Avatar
Not with the heads off, nor if you use a lightweight check spring with the heads on. Only if you are trying to check with regular valve springs in place.
Old 09-21-2011, 10:31 PM
so do i just put my new ls7 lifter in the tray and degree it from there? do i not use the tray, i head the trays keep the lifters suspended off the cam and therefore don't work when degreeing the cam,,, thanks for the help
Old 09-22-2011, 05:35 AM
SweetS10V8's Avatar
Remove the tray so the lifter will stay on the camshaft.
