fast fuel rails leaking
bought brand new fuel rails with lines an all it does is leak where the gauage is an in the rear flex hose. the fuel rail there are alll tight an still leaksso i took it all apart tighten more. turn key an now fuel is spraying outa flex hose wtf so pissed off i spent $400 on this stuff an all it does is leak
Kleeborp the Moderator™
You only need teflon tape/paste on the pipe thread fittings (like the fuel pressure sending unit)...the FAST rails use o-ring boss fittings, so if those are leaking, replace the o-rings. If the braided line itself is leaking, it was assembled incorrectly, and if the AN fittings are leaking, you either have a damaged 37* face that can be fixed by getting some SECO 37* conical seals or replacing the fitting outright. Teflon tape/paste on an AN fitting is a no-no - it won't seal anything, and could end up in your fuel injectors if you use too much.
