Disconnect Battery when putting on SLP Lid?
The purpose is to reset the computer to relearn the A/F settings. It will do this over time anyway, but disconnecting the battery will speed up the process. After the computer relearns the settings, you will be back to square one since it will do its best to match the A/F curve programmed in the computer. In other words, without a tune a CAI doesn't do much at all.
The best that you could hope for long term is slightly improved mpg (assuming the lid is the point of restriction) and slightly better throttle response.
Correct me if I'm wrong, but that is my general understanding of all modern engines.
And disconnecting the negative battery will do the trick.
^^ You're right, all those bolt on non-tuned LS1s that dyno 30+rwhp higher than stock and trap several mph higher are all lies.
I just put in LT's, ported TB, and a lid (plus new plugs/wires over the ORIGINALS and all that jazz) but I bet I didn't gain any power, what a waste of time!
This thread shall be epic.
Yeah I just got done with LT's. Apparently, my computer hasn't reset itself back to OEM settings yet. Still got "sideways on demand"... I do kinda see what stingrayj is saying and to a certain extent I would prolly bet that its true, but numbers and track times don't lie!
LTs will address a significant point of restriction, so you will notice improvement without a tune. However, a lid alone can only do so much. In either case, just bolting stuff on is only the first step. You won't realize the full potential of those parts until you get a proper tune. And I say that based on past experience.
A lid by itself may show some improvement in the 1/4 mile but you're not going to notice much on your daily commute. I'm not saying don't get a lid, rather it is just one piece of the bigger picture. With that said, I plan to get a lid in the near future for my car.
2000, battery, camaro, didnt, disconnect, disconnecting, frost, installing, instructions, lid, ls1, slp, ss, tune, unplug
