LS6 intake Swap.
LS6 intake Swap.
Doing an LS6 swap and i guess what i did lol. Yeah i broke the oil pressure switch haha good think i ordered one when i ordered my knock sensors. **** it took my about 6 hours to just take it off. And damnit is that thing diiiiiirty under there.
That's MISTER MODERATOR
Is there a question here or are you sharing your pain with those of us who've been there, done that?
The PCV piping was probably already shot before you started this project-they all get hot, turn brittle then break just like yours did.
You can do one of two things:
1: Get the GM replacement piping, 12590632, $81.29 at partstaxi.com.
2: Do the LS6 PCV upgrade. More money, more work but a waaay better method of doing it: http://ls1howto.com/index.php?article=18
Yeah sorry lol in my head im asking a questions but when i type it doesnt get on the page lol. But ya i wanna know how to fix that part. can i splice it back together or just fork out the money for new piping.
LS1121 i like that setup lol looks like im doing that. how hard was it to do? im probably goin to have to do this with everything on the car tho.
Removing some of the ridges on the underside of the LS6 intake will let it clear the stock LS1 coolant lines. I chipped them off with a sharp wood chisel.
https://ls1tech.com/forums/generatio...ions-pics.html
Ya stuff some rags into the ports. Some foamy engine degreaser, a gasket scraper and some elbow grease will do the job. Don't forget to remove the rags.
BTW, anytime the intake is off and you're doing other stuff, the intake ports should be stuffed with rags. You'd not want to accidentally drop something into a cylinder
ok well now i know why my sensors had low voltage there was water in there haha i just stuffed a rag in there and let it soak everything up.
