Headers on lowered car
Old 09-29-2011, 10:07 AM
BIGDRAGON's Avatar
Default Headers on lowered car
I did a search and couldn't really find anything, I'm researching which headers have the best ground clearance on a lowered f-body before I pull the trigger.
Old 09-29-2011, 11:57 AM
inssanity21's Avatar
im on the crappy eibach pro kit with bbk LTs + y. the ground clearance is actually better than it was with the factory y.
Old 09-29-2011, 12:20 PM
c0ncEpT's Avatar
Anything but the old style SLP's shouldn't have a problem honestly.
Old 09-29-2011, 12:24 PM
LS-ONE_DAY's Avatar
I've heard ARH has one of the best ground clearances, I'm in talks with ARH stocking dealers now
Old 09-29-2011, 06:16 PM
thegodfather899's Avatar
my y pipe hangs lower than my headers. maybe the y pipe clearance should be your limiting factor
Old 09-29-2011, 06:31 PM
lunatikgixxer's Avatar
Yeah my y pipe hangs lower than the lt's too. On the driver side its a little lower than the passanger. I have sportlines and i barely clip speed bumps if i go over them at an angle.. I think just about any lt will have a problem with ground clearance.
Old 09-29-2011, 07:31 PM
BIGDRAGON's Avatar
So the problem is not the header is the Y-pipe right? which Y-pipe has the clearance? what if I go with catted Y.
Thanks for info.
Old 09-30-2011, 12:06 AM
somws6bird's Avatar
Kooks headers, pick your choice of Y's catted or ORY you shouldn't have any problems. I've got the catted Y and have plenty of room.
Ive also heard good thing's about ARH. You will be fine with either
Old 09-30-2011, 01:52 AM
99Bluz28's Avatar
The headers are still part of the ground clearance issue people have with some exhausts(Headers/Y-pipe) hanging low, it's not only the Y-pipe.
Old 09-30-2011, 02:16 AM
Restricted User
z99ls1's Avatar
My y hits everything. My car sits pretty damn low though. How far lowered are you?
Old 09-30-2011, 02:21 AM
LT1559's Avatar
^^ agreed, my friends 99 z28 had a set of hooker headers with a pacesetter Y pipe and it went over bumps and driveways fine, but once he got the edelbrock 1 3/4 stepped to 1 7/8 with the pacesetter Y it hit everything. I also have the edelbrocks and if you look at the car from the driver side you can CLEARLY see the collector, as opposed to my friend's car who has a set of TSP 1 7/8 longtubes you can't see it at all.
Old 09-30-2011, 09:24 AM
BIGDRAGON's Avatar
I'm leaning toward the Kooks headers and Kooks ORY/Y-catted with solid motor mounts not 100% sure yet.
Old 09-30-2011, 09:51 AM
jhnwlkx86's Avatar
Just did ARH and their ORY.. Y pipe is tucked up way better than the stocker! Im on the pro-kit aswell havent scraped a thing yet! Also did Poly MM's. Best mods yet! Good luck
Old 09-30-2011, 11:56 AM
99Bluz28's Avatar
I've got around a 2" drop, and a hair under 2" ground clearance on the Y-pipe on the driver side.
This is at ride height.
Old 09-30-2011, 05:18 PM
BIGDRAGON's Avatar
What brand of Y-pipe do you have? That's some real nice clearance there.
Old 09-30-2011, 07:16 PM
99Bluz28's Avatar
That's the bbk lt headers and ORY-pipe.
Old 09-30-2011, 07:51 PM
bayer-z28's Avatar
That's not the first time I've heard this!!
Old 10-01-2011, 02:58 PM
99canadahawk's Avatar
Installed SLP`s NEW Design LT Headers just over a month ago & I`ve yet to hit anything with them & I`m on the pro kit .
Old 10-01-2011, 05:28 PM
BIGDRAGON's Avatar
Started removing the old exhaust.
Old 10-01-2011, 06:21 PM
99Bluz28's Avatar
So what did you decide to go with..ARH, Kooks,...?
Quick Reply: Headers on lowered car
