Lightweight/Mini Starter Options for LS1?
Hey All!
I've done a few searches but haven't come up with much.
Is there an option for lightweight/mini starter for the LS1 in a daily driver?
Looking for some reliable weight loss...
Thanks in advance!
Thanks in advance!
powermaster pn 9201 is for LS applications. they don't look that 'mini', but they weigh approx. 8.5 lbs per powermaster's website. here's some more info on mini starters in an LSx application.
1 Post
Thanks for the links! Maybe I overlooked it, but I haven't really seen these mentioned in the 'weight saving' threads.
Does anyone know how much weight you'd save by switching to one of these? Or are they the same weight and mainly just used for clearance issues?
The stock starter is a PMGR (permanent magnet gear reduction) unit and weighs the same 8.5lbs. I really don't think you would get any better than that.
A typical swap for older GM cars and trucks is to install a late 90's PMGR starter from a 5.7L (ACDelco PN 336-1910A). I swapped my 20lb original starter for the PMGR on my 80 Corvette. It's smaller, lighter and spins the engine over with ease.
Remember, in the late 90's GM was in a desperate situation with trying to meet federal emissions, so they were trying to reduce weight.
1 Post
i havent heard of too many DD putting in a lightweight starter. I would take the stocker over most aftermarket ones due to reliability. mines got over 100k miles on it and still cranks without a hitch with the added nearly 200hp over stock power.
The stocker is already pretty light at around 11lbs. Also no headaches like most aftermarket starters. They are also cheap.
You would be better served by running a lightweight battery.....
http://www.powersports.braillebatter...atteries/b129/
