PCV delete
Don't do breathers and catchcans. Get you an LS6 valley cover for about $70 and its matching hose $5. Cap your rear 2 ports on your valve covers and your done.
Deleting the PCV is the only 100% way to ensure that you don't get oil into the intake. It doesn't matter what valley cover you use when you delete it. Yank all the lines out. Run a little breather on rear of the driver side cover. Cap the fittings on the passenger side and run a breather on the oil fill hole. Be sure to cap off the intake and the TB or else you'll have a vacuum leak.
I respect that you are a Moderator but why do you say no on the breathers??? everything i read seems to say its all good and you can tune everything out.
