True dual question. (not the normal question)
if space wasn't a obstacle. what 2 full size mufflers would be the best for a quiet dual setup for a 404 nitrous motor setup. the exhaust will be dumped around the same place. just im planing on having alot of room so im looking for a set of full size mufflers. right now im leaning towards a set of hooker max flows.
im planing on mini tubing the project car. and at the same time ima cut out the rear seat pans and raise them up making more than plenty of enuff room to fit 2 full size mufflers under it.
justa fyi on the motor going in the car. lq4 block. 404 11.75 compression. pr3 ls3/l92 heads with prc .675 spring kit. crank is a callies comp star. rods are callies compstar. pistons are wiseco with grx steel top/napier 2nd ring set. arp head studs. arp main studs. Cometic head gaskets. Melling High Volume Oil Pump. tsp 1 7/8 headers(looking for kooks 2" primary headers with 3.5 collectors in the future) tsp duals (ima modify and take the dynomax race bullets out in favor of a full size muffler) Fast 102 intake. fast 102mm throttle body. tsp 100mm mass air. ftp 104mm lid. chris ram intake....etc etc theres shitload more. race built th400. 3800 nitrous stall. trans brake with fmvb. everything is setup for nitrous. cam size is 248/256 .622/614
if that will give anybody the hint of the motor im trying to tame the sound down on.
