coil packs ??? what swaps ???
Old 12-04-2011, 05:53 PM
Doug G's Avatar
Default coil packs ??? what swaps ???
What coil packs interchange ?
Are they all the same ??
Old 12-04-2011, 06:13 PM
djfury05's Avatar
Depends.. some coils have different mounting bolt spacing.. some need the correct harness with the plugs that work for the coil itself.. all LS coil harness utilize the same main pack connector that connects to the PCM harness near the fuel rails though.
For example, I had LS1 coils on my car. I just bought part #12611424, which appear on C6's, 2010+ Camaro's, LSA engines etc. I had to get the harnesses to go with since my LS1 coil plug harness wouldn't plug into the coils.
Old 12-05-2011, 02:17 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Nope, they're different.
Here's all you need to know:
https://ls1tech.com/forums/generatio...ke-sticky.html
Old 12-05-2011, 12:01 PM
lemkerailroad's Avatar
very good post and link
lots of good info, but untill i see more people with a gain in hp i think i will stay with what i have
Old 12-06-2011, 04:40 AM
Doug G's Avatar
Thanks... just what I need
Old 12-06-2011, 07:00 AM
Paul Bell's Avatar
Most people doing the upgrade to truck coils have seen some improvement. In my case, I had a power increase as shown in back to back dyno tests. Even if HP & torque don't go up, engine response improves.
Even if no power increase is documented, the engine will more often than not run better.
I do believe the more other improvements done to the engine, the better the coil upgrade improvements will be.
Old 12-15-2011, 04:35 PM
LSxChevelle's Avatar
Are the 19005218 good ones to use?
Old 12-15-2011, 04:47 PM
And to clarify on connectors...the connector at the coil has the only difference? The big connector by fuel rail is the same on all LS stuff?
Old 12-15-2011, 06:27 PM
Paul Bell's Avatar
Yes, that's this one that's the "truck coil"
Old 12-15-2011, 06:29 PM
Paul Bell's Avatar
As far as connectors are concerned, yes, the engine harness to coil harness connector is the same regardless of which coil harness you choose. The coil end plug is different. There's LS1/6 style and then there's LS2/3/5/7 and all the truck motors.
Old 12-15-2011, 06:43 PM
Ok, so key to running is having matching harness (4-1 harness).
Thanks, will purchase coils!
Old 12-15-2011, 09:04 PM
cookba's Avatar
also:
https://ls1tech.com/forums/generatio...ve-covers.html
Old 12-15-2011, 09:54 PM
Paul Bell's Avatar
I don't see the advantage to using the LS9 VC. On a 4th gen, pulling the coil packs as one unit makes spark plugs worlds easier.
Quick Reply: coil packs ??? what swaps ???
