Header burnt thru this wire, can you identify it? May be cause of ruf idle..
Ok I was cleaning engine bay and car was off. Then next day after about 2 mins of idling fine, it just started to idle very rough, sputtering and dying out. I thought I pulled a wire somewhere. I checked fuel pressure, it was fine...it sounds so bad for a bit and vibrates horribly then dies.
So today I saw this wire resting on the header itself and the heat burned right through it. Its on the passenger side running down. Can you tell me what it goes to and if THIS could be whats causing my rough idle and dying out. Prior to this the car was running like a champ. If this is the problem can I just splice into the top part where there is good wire/s and then run new wire/s down to below the burnt part and splice in where it's not burnt?
Thanks
Thanks
that is the abs sensor wire . take your right front tire off and you'll find where it goes the only other wire there is the starter solinoid wire. if you burned it in two you would not start.
That's MISTER MODERATOR
I like your A.I.R. delete "plates".
I do not believe a fault in the ABS system will affect the engine's running condition. If in fact this is your ABS sensor wire and your ABS light is on, it's not what's causing the poorly running engine.
Burned open or shorted ABS wiring or even O2 wiring would not prevent the engine from running. As you say it dies after starting, look elsewhere.
Yeah .... I like my plates too... they do the job! kinda homemade tho but it works.
Im going to start a different thread though because I think ....my engine block cracked! which would suck hard Ballz.
