is my asp underdrive pulley all the way in?
Old 12-21-2011, 06:46 PM
mondols1's Avatar
Default is my asp underdrive pulley all the way in?
i'm reinstalling my asp underdrive pulley after an oil pump change/upgrade. i didnt take any pictures prior to removal so i cant compare where it sits now vs before. but i can still see about 1/4" of the shiny part of the shaft.
i thought that the 1st step down/lip on the shaft from the pulley was going to butt up against the seal but it's about 1/4" away and i cant get it to budge any further. the pulleys look like they line up fairly close. not that it should matter but im running a double roller chain an everything has been clearenced properly and been in service for about 30k miles.
Old 12-21-2011, 06:56 PM
Deviant LS1's Avatar
You'll see a little bit of it. Put the belts on and check your alignment that way. You'll defintely be able to tell if the pulley off when you put the belts on.
Old 12-21-2011, 07:44 PM
mondols1's Avatar
yea, i'll put the water pump on it tomorrow and see how the belts line up.
Old 12-23-2011, 04:36 PM
mondols1's Avatar
once i threw the belts on it lined up. tks
