oil pressure problem
ill see if i can get a pic of one from him its just been an ongoing oil pressure problem trying to get all the ideas possible to fix it before the motor gets torn into again id rather not have the same problem again and again.
Dont know who told you that, but You are getting some bad information. Bearings do have a tapered edge that corresponds with the tapered edge of the large rod end. Bearings are flat on the ends, they but up against each other. Your chain is being yanked.
Picture will be priceless.
