Question about truck fuel rail
Ok im swapping a truck 5.3 into my 71 c10 and getting all of the fuel system ironed out. I want to run the corvette style filter/regulator so i dont have to have a long return line back to the fuel cell but my truck engine has the return style fuel rail. My question is what is the easiest way to accomplish this? Can i run the corvette style filter/regulator to the inlet of the fuel rail and then plug the fuel return? or should i swap the fuel rail with one that is a return-less fuel rail?
Thanks for the help.
1 Post
Are you talking about the port on the back of the regulator that's mounted to the fuel rail? That's not a return line to my knowledge, that's a vacuum port. The tunes run a straight fuel pressure reading for the injectors and the regulator varies fuel pressure via vacuum. On a sealed regulator (car) setup, the fuel pressure is fixed and the injector data is offset via the MAP sensor reading.
I understand in the stock configuration that the fuel regulator gets a vacuum feed to determine the correct fuel pressure. what i was thinking about doing was capping that vacuum port and running a plug instead of a return line. and have the fuel filter do the regulating. Would that mess anything up?
