cut up exhaust pipes,,, do they make tape?
cut up a C5 exhaust in order to gut the cats. is there any way to "tape" up the exhaust pipe. For example: take a 4 foot strait piece of exhaust pipe and cut it in half = 2 two foot pieces of strait exhaust pipe. Now is there any way to re-join these two pieces of pipe together without a torch and welder?
WHAT you do need is to take both pieces to an exhaust shop...Have both ends of one pipe stretched to suit so they will fit over the existing pipe & the second pipe....2nd pipe stretched one end only so it goes over existing & inside the 1st pipe.
Fit so the pipe from header end has the one stretch only
Use exhaust pipe clamps to help hold together.
Do not butt join unless you weld together...It 'WILL' leak.
