larger than 72cc chamber heads?
Old 01-10-2012, 07:52 PM
quik01ss's Avatar
Default larger than 72cc chamber heads?
does anyone make a larger cc chamber head then stock 72cc looking for 80cc chamber if not changing piston...
Old 01-10-2012, 10:20 PM
JPH
JPH's Avatar
Have a cylinder head guy open the chambers up a few ccs and play around with gasket bore/thickness to achieve your intended SCR is about your only choice.
Old 01-11-2012, 12:20 AM
bww3588's Avatar
What compression ratio are you shooting for? What pistons do you currently have?
Old 01-11-2012, 04:21 PM
quik01ss's Avatar
4.005 -8cc piston 60cc chamber right not have 11.5 cr want to get to 9.5 cr but i think its just gona hav to get a dished piston
Old 01-11-2012, 06:28 PM
JPH
JPH's Avatar
Yes, I would have to say it would. What is the SCR with a 72cc head?
Old 01-11-2012, 06:47 PM
bww3588's Avatar
With an 8 cc dish in your current piston and 71.5 cc chambers you should have what you need.
Old 01-11-2012, 08:53 PM
quik01ss's Avatar
with a stock 72cc 317 head it is 10.13cr just gona have to switch out the pistons to -28cc get me to 9.3cr
Old 01-12-2012, 07:13 AM
bww3588's Avatar
with a 28cc dished piston, assuming you are using stock thickness gasket, you will be at about 8.3 to 1
by my calculations, providing you use a .040 gasket with a 4.060 gasket bore, you will need a 20 cc dished piston, or with a 28 cc dished piston you will need to mill your heads to 63cc's
Old 01-13-2012, 10:50 AM
JPH
JPH's Avatar
Give me your current piston cc spec, head cc spec, gasket spec and bore/stroke and deck height(if known) and let me calculate your SCR. Got to many different answers going on here.
Old 01-14-2012, 10:07 PM
quik01ss's Avatar
Its 4.005 bore
Bore.......4.005
Stroke....4.00
Piston...... -32 cc
Head......60 cc
Head gasket bore....4.100
Head gasket thick....0.53
Meased piston out of hole ....0.005 out
Scr.......9.04 :1
Old 01-15-2012, 02:28 AM
bww3588's Avatar
Its 4.005 bore
Bore.......4.005
Stroke....4.00
Piston...... -32 cc
Head......60 cc
Scr.......9.04 :1
again, assumed measurements...how do you know he is using a 4.100 bore gasket? how do you know they are .005 out of the hole?
I'd say good thinking tho. looks to be ballpark, but never 100% accurate until OP gives exact measurements.
Old 01-15-2012, 11:00 AM
quik01ss's Avatar
I am the OP......lol... im building my own motor again ....the n/a style 403 i built yeilded a .005 out hole pistion so using the same company piston just -32cc this time give or take some thousandths.... head gasket is ls9 thats there specs....
Old 01-15-2012, 03:21 PM
bww3588's Avatar
Sorry, I was a bit...intoxicated last night.
Quick Reply: larger than 72cc chamber heads?
