Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Generation III External Engine
Sign in using an external account
Register Forgot Password?
LS1 | LS6 | Bolt-Ons | Intakes | Exhaust | Ignition | Accessories
Sponsored by
CBM Motorsports
Thread Tools Search this Thread
Old 01-27-2012, 09:35 PM   #1
Garage is empty, add now
dr_whigham's Avatar
Trader Rating: 26
Default TSP Headers & Y install pics; FINALLY
PLEASE DON'T QUOTE PICS!!!!
I wanted to post pics of my install like I said. Sorry it took a few months
to get around to it.
I had a thread started here, UPDATE: Anniversary gift from my AWESOME wife, w/ help from TSP & Ed Curtis!!
A lot of you commented and said some nice things.
I figured the least I could do is post my results.
Thanks to all the knowledge on this site, it was a truly trouble free install.
Light grinding on the K for the #5 or 7 primary (cant remember which)
and a small cut for the collector.
I'm sure polys wont have this, but I installed Spohn's.
In my mind, its a fucking pony car, not a luxury sedan, or a Corvette.
I wanted to FEEL the car. That has now been achieved.
Again, thanks for all who commented on the other thread and the
kind words.
Enough of the sappy shit. Here's the pics
LS6 Valley was the first thing done after pulling the manifold.
Best thing I found to clean the heads and all was a small
spray bottle filled with running alcohol.
Cut that old caked oil like nothing.
With the Spohn's raising the engine slightly, the collector was
too close to the body to slip on the first pipe of the Y. So, out
came baby Bertha, and we fixed that.
After BFH:
After that, the first pipe of the Y found a new place to rest against the car
Another shot of clearence, and my sweet woodland digitals
MY remedy. I'm sure not all would do this, but it's not like it's going to affect anything.
Y installed with SLP LM1
As you can see here, the resonator is actually the lowest part of the system. That's going to be remedied in due time, however....
So there we have it.
PLEASE DONT QUOTE PICS!!!!
__________________
01 SS Blk M6 #1489
Chrs1313 Non-AC RA, SLP Lid, Saxon MAF, Shaner S3 TB, FAST 78, 04+LS6 Valley, LS6 Block, Spohn Solids
MSD, TSP 1 7/8" SS Headers, TSP SS ORY w/ True 3" Merge, MGW / GTO Knob, Prothane Trans Mnt, SLP MagnaMouth, FROST Tune
Ed Curtis Custom Cam: big/bigger .high.higher
dr_whigham is online now   Reply With Quote
Old 01-27-2012, 09:44 PM   #2
BIGDRAGON's Avatar
Trader Rating: 1
Looks good Sir.
__________________
Mods are SLP lid with K&N,SLP smoth bellow,Fast 102,NW102,TSP 1 7/8 LT headers,TSP un-catted Y-pipe follow by 3" pipe to a Magnaflow muffler,Poly MM,MSD wires,NGK iridium plugs,UMI subframe connectors,UMI strut bar,UMI lca ,UMI drag sway bar,Hurts shifter,4:10 gears,M6 and AI/Ported 243 heads,Cam 226.234.599.599.112 chrome molly push rods,tuned by SQR 441RWHP/381RWTorque.
http://i94.photobucket.com/albums/l1...E04GLI/026.jpg
BIGDRAGON is offline   Reply With Quote
Old 01-28-2012, 12:18 AM   #3
94Z28-MSTGKLR's Avatar
Trader Rating: 5
I was going to buy these and install poly motor mounts but after all the cutting and banging you had to do, I think I'll spend my hard earned money on something I don't have to destroy my car to get fitted.
__________________
99 SS M6 SLP #45. SLP Lid, MSD Wires, Kooks 1 7/8, Kooks ORY, GMMG, Monster Level 1, TP Adj MC, Pro 5.0, Lou's SS.
94Z28-MSTGKLR is offline   Reply With Quote
Old 01-28-2012, 12:45 AM   #4
2000 Chevrolet Camaro
jsteele90's Avatar
Trader Rating: 12
Send a message via AIM to jsteele90 Send a message via Yahoo to jsteele90
well at least the merge is better on the new tsp y pipe. the one i hasd was awful. what did you use on your drivers side valve cover to plug the pcv. a nut and a bolt? lol.
__________________
243 heads/224 cam/YANK SS3600/3.73s
11.9@112@3575 DA. www.socalmuscle.net
jsteele90 is offline   Reply With Quote
Old 01-28-2012, 01:01 AM   #5
1998 Pontiac Trans Am
lemons12's Avatar
Trader Rating: 53
That is probably a freeze plug.
I hope all the TSPs aren't this bad.
__________________
Quote:
Originally Posted by chaman View Post
Lemons talks the truth...as always. Unless he is lying...LOL!
lemons12 is offline   Reply With Quote
Old 01-28-2012, 01:13 AM   #6
LS1Tech Platinum Sponsor
Trader Rating: 0
Keep in mind he swapped to the Spohn solid mounts that raised everything up a noticeable amount. I used solid UMI mounts on my personal build that changed the placement of the engine ever so slightly as well, but our TSP y went on without issue with that setup. My guess is Spohns raise everything considerably more from the OPs pictures and that clearance would have been tight with any exhaust setup he chose.
__________________
Aaron@Texas-Speed is online now   Reply With Quote
Old 01-28-2012, 01:21 AM   #7
lemons12's Avatar
Trader Rating: 53
Aaron, I will trade you a set of Kooks 13/4 stainless for some TSP 17/8!
Going blower and I think it would appreciate the added primary size a good bit.
__________________
Old 01-28-2012, 01:51 AM   #8
dr_whigham's Avatar
Trader Rating: 26
Quote:
If you read the thread instead of just looking at the pictures, you'd see where I explicitly said I ran with Spohn Solids, and why. Yes, it raises the engine a good .75 to an inch. And what the fuck is getting destroyed? Worse damage has been had trying to run 315's.
Not all of us wear a skirt when we drive our cars.
Quote:
Yes, it is a freeze plug. I had it left over from when I tried to use it in my LT1 radiator in the coolant level sensor location. Apparently it didn't like the pressure and spit it out in the driveway. Fit perfectly there in the valve cover though.
I didn't really think it was all that bad guys, seriously. It's one cut in that little rail. Nothing really.
__________________
01 SS Blk M6 #1489
Old 01-28-2012, 01:58 AM   #9
lemons12's Avatar
Trader Rating: 53
I absolutely refuse to do something like that if I don't have to. Did you destroy your car? Most definitely not, but I won't be doing it. I will just continue running my Kooks.
I would rather spend 300$ more and go coated than have to do something like that. That will be there forever and I like my car looking good on a lift, not just rolling around.
I'm just picky...
TSP- Are all TSP 1 7/8s like this? I will be returning them when I purchase them if I have to cut my car, period.... Honestly, won't even bang the floor board. The normal part you bang for say a Pacesetter install, fine.. But not under the car.
__________________
Old 01-28-2012, 02:15 AM   #10
Trader Rating: 0
I'm just picky...
As mentioned before the issue that OP was dealing with was due to raised engine placement caused by the Spohn solid mounts. I haven't personally installed the Spohn mounts and completed a before and after measurement of engine height, but when OP claims 3/4 to 1 inch difference in engine height from stock that most definitely is why he was having some issues. I also mentioned above that I personally installed the UMI solid mounts on my car that raised everything up about 1/4 inch and I still had no issues what so ever. Obviously the more the motor is raised the more clearance issues that will arise. This goes for any header setup.
__________________
Old 01-28-2012, 02:17 AM   #11
lemons12's Avatar
Trader Rating: 53
Sounds good..
__________________
Old 01-28-2012, 02:54 AM   #12
dr_whigham's Avatar
Trader Rating: 26
Well put Aaron.
Lemons, I assure you you won't have to do ANYTHING like I did. As said, I knew full well what I was going to have to do.
Makes you really consider how well they are made though. If I only raised my engine an inch or so, imagine how well they
will tuck for you guys running poly mounts or aftermarket K's.
Kiss clearence issues goodbye.
__________________
01 SS Blk M6 #1489
Old 01-28-2012, 03:13 AM   #13
lemons12's Avatar
Trader Rating: 53
Not worried about clearance honestly. Car is drove 1-2 times a week max... I never have to go over a speed bump, have good roads, etc... If it scrapes its because I'm not paying attention or being an idiot (which doesn't happen in the TA).
I have never scrapped my Kooks setup I had and I'm lowered 1.25 on BMRs.
__________________
Old 01-28-2012, 04:43 AM   #14
sjsingle1's Avatar
Trader Rating: 0
so how much did you have to grind the k?
sjsingle1 is offline   Reply With Quote
Old 01-28-2012, 04:59 AM   #15
need4fun2469's Avatar
Trader Rating: 0
Aaron, when are you going to have 1 7/8 ss headers in stock?
__________________
2002 SOM WS6/3200 vig/baby cam/TSP SS 1 7/8 headers & ory-pipe/Hooker catback/Pat G tune/QP 9" w/spool
need4fun2469 is offline   Reply With Quote
Old 01-28-2012, 06:11 AM   #16
dr_whigham's Avatar
Trader Rating: 26
Quote:
God's honest truth, just about an 8th of an inch deep, and about an inch and a half across. Just a small piece of the lip itself from the stamped steel. Didn't even penetrate into the hollow part.
Guys, I can't stress this enough, I went with the Spohn Solids. I'm telling you right now, with Poly's you won't have to do shit. With my stockers in place I test fit them and they slid in beautifully.
I did NOT have to drop my starter either.
__________________
01 SS Blk M6 #1489
Old 01-28-2012, 09:12 AM   #17
LS1Tech Premium Sponsor
UMI Performance's Avatar
Trader Rating: 70
Quote:
Aaron is correct, any type of engine movement will effect how an exhaust system fits. Our mounts like Aaron mentioned will keep the engine almost identical to stock, the only reason for the slight lift is they take out the sag of the factory rubber bushings.
UMI Performance is offline   Reply With Quote
Old 01-28-2012, 09:21 AM   #18
Trader Rating: 16
Looks good, from one Marine to another please be careful using 2x4s under the K like that. If you need more lift get a 2x12 cut it down and throw one under each stand.
Now for the question, think there will be an issue running a aftermarket intake in the future because of the lost clearance?
__________________
I tried to get out of the F-Body game, couldn't sell my car for what I felt it was worth. So I did the next best thing...and bought another one.
got milk?? is offline   Reply With Quote
Old 01-28-2012, 09:24 AM   #19
Trader Rating: 2
headers look nice , when i go with the new motor i will have to get me a set
BOBS99SS is online now   Reply With Quote
Old 01-28-2012, 11:08 AM   #20
Bramlok's Avatar
Trader Rating: 6
I helped a friend do his TSP 1 7/8 headers and poly mounts last week. The only problem we ran into was jacking the motor up high enough to get the headers to slide into place.
First we did the poly mounts and of course it was a bitch to get them lined up to get the bolts in. When we finally got the bolts in, there was not enough room to slide the headers. So we had to remove the motor mount bolts, jack the motor up from the oil pan, and then we were able to get the headers in place. After that, we had a hell of a time lining up the motor mounts again to get the bolts back in again. It made it worse with the headers in the way.
We already had the steering shaft off, oil filter and drain plug and starter removed so it was still a tight fit. It was cold in the garage lying on the concrete and that made things worse. A nice warm day would have made everything go a little easier. However once everything was back together, they fit and looked great with no clearance issues.
Bramlok is offline   Reply With Quote
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
2012, 34, 78, car, headers, ls1tech, mounts, poly, powered, propane, radiators, review, stainless, tank, tsp, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
