HELP: Where to buy LS1 H/T lead kit
Old 02-06-2012, 09:06 PM
ls1 1990 VN's Avatar
Default HELP: Where to buy LS1 H/T lead kit
Hi guys, Where can I buy over there an LS1 8mm or 10mm H/T lead kit that has longer wires, spark plug & coil terminals & boots loose in the packet.
Also need enough heat shield boot as well.
Because my cars a Hybrid I need to make the leads to suit.
I need a firm that delivers internationally.
Cheers
Old 02-06-2012, 09:55 PM
38 views & no-one knows where I can get some!!
I realise you guys just buy standard length so wouldn't even have to bother enquiring but some-one must've seen or heard about a kit hopefully.
Old 02-06-2012, 11:13 PM
sjsingle1's Avatar
MSD does have build your own wire set kits.....sure you could make it work for your application
Old 02-06-2012, 11:24 PM
Mako77's Avatar
Prolly need a custom build set.
Old 02-06-2012, 11:44 PM
Blk98Vert's Avatar
Yep MSD or Taylor. Go to summitracing.com they should ship internationally and have what you need
Old 02-07-2012, 03:03 AM
I had a quick look at the Summit site but couldn't find a do it yourself kit, guess I'll have to look a bit harder.
