don't flame me plz lol
ok i will be building a lq4 with 317 heads, i know everyone says go 243 but these are free and for me free is anyway, i will be running a 222/226 eps cam i want to mill the 317s down a little to up compression, my question is how much can i go before i have ptv issues and have to change push rods and any thing else that might come into play. also i want to still be able to run 87 oct if possible or next grade up
Premium gas isn't that much more expensive ffs. On a fill up, you're gettin maybe 1 gallon less with premium for the same amount of cash. If you can't afford premium gas, you should drive something more economical.
Nothing wrong with 317's, they are the Same essentially as the 243, Just with a larger combustion chamber. A good mill and a thinner than stock gasket will bring you right on par with a 243 head.
And I agree, generally premium gas is 20 cents more a gallon than regular. On a typical 10 ish gallon fill up, you Will spend 2 bucks more going with premium, and your car will thank you in the end.
Sorry to hi jack, but I'm thinking of sending my 317's down to be milled to bump compression a little. If I have the machine shop take off .040", will that cause any intake fitment issues?
